Need help id'ing these hubcaps
petty437
Kent, Ohio
I have a set of these but don't know where I got them or what they are off of! LOL
Edit;
What Rani says, below.
It is fairly common for truck & car lines to share the same type of hubcap.
Negative Ghostrider
1965 and 66 dodge.
Those are the 10 inch caps so you need the older 65 and 66 type wheels with the 10 inch nubby circle on the wheel. 67 and up they went to the 8.75" center nubby circle. These caps are not very popular these days because the wheels that correspond are really hard to find.
These hub caps were common on base model coronets and polaras and some others but mostly bigger cars.
Thanks Rani!
I'll edit the post above to reflect my mistake.
Every mistake made is a chance to learn, so at my age I am proud of my mistakes. ;-)
Negative Ghostrider
1965 and 66 dodge.
I told yall Littler Miss Badassary would be in here in a minute. LOL
The wheels for these caps are NOT hard to find , what size do you need ???
I have plenty of centers that can be made into wheels for these dogdish caps.
Also these can be used on cars and trucks......
Frank
