I have a 1966 dart gt that had a 225 that i pulled and rebuilt a 318 to go in . I have the mount and brackets for the 318, 904 rebuilt on it , but the k frame from a 1966 273 seems to line up but the oil pan is hitting. i need a rear sump pan , so i removed the oil pan and fit the k-frame to the engine it seems that it might fit if i changed the oil pan but i'm not sure i'm on the right track ,and i am getting frustated. if you can help pictures also.
thanks
thanks
