Need help selecting engine harness
Ryan ekes
Coulterville il
Anyone know what engine harness I should use for a 67 barracuda with original style dash harness and a 1973 340 motor with electric ignition? Called classic industries and didn't get much input. I seen they have a engine/forward light harness but dunno if could use that or need separate ones to work with what I have in the dash already
I would contact Year One. I bought one for my Dart two years ago and the quality was top notch. They are made by M&H and sold exclusively through Year One. Member @VOETOM was so impressed with my harness he bought a complete wiring harness for his Barracuda.
I bought this engine/forward light harness because I was converting over to a MSD ignition. It's for the original points style ignition. They make one that allows you to plug and play a Mopar module and ballast resistor but you'd have to call them and get that part number.
1966-74 A B E-Body Engine Forward Light Harness 1967 Valiant Dart
They are offering free shipping through Sunday night and you might be able to find a discount code if you search around. I had it in my shopping cart and they emailed me the next day with a 10% off code. It's worth a shot.
Evans wiring harnesses! I put a 72 340 with electronic ignition into my 68 Dart. I called Bill and he took care of me. The engine harness plugged right in and worked perfectly.
EvansWiring.com
He has the engine harness you need in his product catalog.
67 A-body (small or big block) with electronic ignition.
You can get a modified unit for Chrysler electronic boxes that is very well built. I used the bone stock harness and went pertronix and it is all hidden. Looks bone stock. Big fan of M&H!
Thanks for the input man it's greatly appreciated!
I'll throw a plug in for Evans as well. I Have bought all of my original/custom harnesses from Bill & Rose going back 20+ years. They will build whatever Frankenstein harness you need.
