Dusterdude72
IN MOPAR MUSCLE MAGAZINE
Hey guys ,
Looking for some input on this issue I have.
so I was having a rich running condition for awhile and I finally got a pressure gauge and seen I was running 9.5psi from my pump to the carb. so I picked up a holley regulator and installed it and dialed it down to 6.5 psi. Car runs great and the rich issue cleared up alot.
however....my new issue has been that after I shut the car off. I can get out and look under the hood at my fuel pressure gauge and see it still holds the 6.5psi pressure in the line. and it takes about 20 minutes or so before that pressure leaks back down to 0psi.
the issue is that since I installed the regulator I can smell gas from my carburetor. And after it has been running and then shut down and left to sit for more than a couple minutes it is hard to start. it will crank over a few times before it finally starts up.
what I think is happening is the pressure in the line is holding after the engine has shut down and the that pressure bleeds fuel off down the carb which in turn floods it out a bit and makes for a hard start.
so what I tried today was installing a return line. on my regulator I have 1 inlet and 2 outlets. I have my pump going to the inlet and I have one outlet plumbed to the carb and I plumbed the other outlet to the return line that runs to the tank.
by doing this I solved the issue of the line holding pressure after the engine has been shut off, and I solved the issue of the gas smell and the hard start issue seems to be gone aswell. BUT now I can't read my fuel pressure gauge (its bounces all over the place as if its reading each individual pulse of the pump). and the other issue is that by giving an additional path for the fuel to escape I dont think the pressure at the carb is correct any longer. when I first fire it up it wants to stall and the idle is sporadic and I have to crank the fuel pressure way up just to clear the idle up some.
so my question is.....what do you guys think is going on and what suggestions might you have for me?.
it ran great with just the fuel pump hooked to the inlet and one outlet going to the carb and the other outlet blocked off. my complaint with it set up that way was the fuel smell and the hard start.
Thanks in advance for any help guys.
