rod7515
Im working on a 66 Dart 2 door. I bought pin and bushing kits for all 4 hinges. Each kit comes with 2 pins and 4 bushings. The top hinge is easy as the hinges have bushings already in them so you drive them out and install the new bushings and your done since the outside of the hinge doesnt wear. Now the lower ones are different. First they didnt have bushings from original. Second the inner half of the hinge has some wear so the pin is sloppy and lastly the bushing that comes with the kit have no install instructions. Im not sure how the bushing should be installed. I know I will need to drill the inner half of the hinge so the bushing can be installed. Which direction do the bushings get put in from and what is the best way to drill the hinge so its done straight. Does anyone have pics on what the hinge will look like once this is done and what steps do I need to take to get this right?
Here are a few pics of what I have. The new pins and bushings are just sitting in there so they dont get lost. They are not together as a final part!
Thanks Rod
Thanks Rod
