Rockauto gives bore diameters for many of the MC's they list. In A's, manual bores (~1"D) are usually a bit larger than power (~15/16'D). That is due to the lever ratio in the power boosters.
As RedFish and 67Dart273 said, the prop valves were tuned for a certain front, rear disk combination, and many other variables. I am guessing most people don't have the original friction materials (asbestos) in the pads and shoes, nor the original skinny bias-ply tires, nor the same weight distribution, and often not the original wheels. Ideally, you test where skidding occurs on a wet parking lot. Ideally, adjust it until the fronts skid just before the rears. Easy to do with an adjustable prop valve. Otherwise, you would have to change rear wheel cylinders or such to change the ratio.
