OK, this is the first time I have redone a mopar engine. I have only done chebbys in the past and have to tell you it has been a long time since I touched an engine period. I just put rings and bearings in my sons 360 before setting it down in the car. In turning the motor over on the engine stand, the gear for the dist. fell out.Check me out here before I crank this engine over. Attn: I am not a mechanic. But I have put a few engines together. I put no. 1 piston TDC. I put the shaft for the dist. in where the slot is parallel to the crank. I dropped the dist. down in where the button is pointing towards the pass. side front of engine about where #2 cyl. is located. this is what I got from my chiltons manual. My problem is that the timing mark does not line up on 0. It is about 10 degrees. I am thinking that the piston may be a little too high so I figure the adjustment in the dist. will compensate for that once it is running. I didnt mess with any timing chain, cam or anything like that. I just pulled the pistons and put new bearings and re-ringed it after I honed the cyl. of course. now, tell me if I am good to go on cranking this puppy over. Mopars are a little different than chebbys. This motor had 43000 miles on it but had sat a little while so I wanted to do the rings and bearings. thanks for your help.Bill
