Deleted Member
- Joined
- May 20, 2019
- Messages
- 265
- Reaction score
- 57
Welp good news , I got the fresh wheel and tires for the dart . Bad news is that I rub on the passenger front fender when turning. Only on that side , only on the front fender lip
Should I hold off on cutting the fender on the passenger side until the front end is rebuilt and aligned? The driver side looks like it's been cut back in the past as you can see in the pic . It's real close and the front suspension is quite worn. The rears for no issues. The tires are about 1in taller than stock , I couldn't get a whitewall (girlfriend requirement) in the stock size that wasn't a no name brand
15x7 wheel vintiques 4x5 rally wheel
205/70r15 Toyo
I'm hoping the suspension is just out of wack ? It drove nicely down the road on the shot 13s/tires with a slight alignment issue/pull. All the suspension bushings looks old as hell .they are all on order.
205/70r15 Toyo
