midnight340
In my original post I was struggling to get timing and fuel worked out. The post generated a number of helpful responses and suggestions of things to take care of. I've done that and want to update and get response. I'll post what I've done + photos of test plugs.
For anyone who wants this info:
.040" over 340, TRW 8.5 forged pistons, I do not know deck/piston height, 70cc heads, conservative Lunati 284 Bracket Master II .458" lift (218 at .050), 1-58" mid length headers, LD340 intake, Edelbrock 650 AVS (1" phenolic spacer). Heads are X heads ported, cylinder pressure is an even 160#.
A couple of times I ran 98+ mph with a weight of about 3400# (13.95) But this was a number of years back and I have no idea how I had timing or jetting set. Have upgraded lots since.
I have a new Ready-to-Run MSD distributor firing a MSD 6A box, new wires, etc. Distr. curve all in at 2500, and I had been advised to sort out the timing first, so have since installed a 10* bushing. (also vac adv limited to 10*) and am currently running 22-32 degrees.
When I began trying to sort out the tuning with the new distributor and a new AEM A/F meter with Bosch sensor, I was struggling to get decent #'s and having WOT detonation problems, seeing silver specks on the plugs. So have been jetting richer and holding back the timing. I am using fresh NGK BPR8ES plugs for testing.
Because of the detonation at WOT, I was told to "get some color on those plugs" before adding any timing. So I've been working on the jetting since.
I was running an Edelbrock 750, I did a lot of research, some saying that model had some design problems making it hard to get rid of lean conditions. After struggling with it, I bought a new 650 AVS. (the secondaries in the 650 AVS are actually larger than those of the 750, and the small primaries help throttle response.)
Trying to cover everything, I taped a fuel pressure gauge to the windshield and found I had fuel pressure dropping as I ran through the power band, so I have replaced the Holley red pump with a new Blue, and it now maintains pressure. So that eliminates any fuel issue I believe.
The advice I got here was to ignore the A/F meter until I got close. Also to throw away the Edelbrock book and pay attention to what the motor wants. So I have been doing that.
With the Edelbrock 650 AVS stock jetting I was very lean and very down on power. So I began moving up in jetting. But in the secondaries I am now running the second largest jet Edelbrock makes!!! I am jetted .104 in the primaries (3 steps up from stock .095) and my secondaries are …seriously, 6 (that's SIX) steps up with .116's. And the motor is finally feeling like it has power. Much more willing to run.
(I suspected a vacuum leak could be messing with things, so replaced all hoses and connections. Also ran raw propane all over hoses and intake. No imdication of any leaks.)
Yesterday I did two back to back WOT runs (probably 3/8 mile) with two fresh NGK's in #1 and #7 shutting it off and coasting to a stop. Only when I hold the test plugs next to a new one in the bright sun do I pick up any color at all, and it is a very faint light tan. (My run around town plugs have a black ring at the very base of the porcelain and a thin black 3/4 of the way around the plug base.)
So I have a hard time believing that I'm only running 32* total, and am six steps up in secondary jetting, and barely getting any color on the plugs. Any time I add more timing I run into detonation.
Possibly my timing light is a slight bit off, but the 340 sounds like it should set by this light. Starts very well, and runs cool. Yes, I have checked TDC at the piston, and I have a fully degreed balancer. I am NOT using a dial back light (which can cause problems with MSD.)
For what it's worth my A/F is now in the 11-11.5 range WOT and the 340 is finally pulling pretty decent through 5500+ (I've held off some due to apparent lean conditions) It used to rev willingly to 7,000 even with this cam. Idle #'s are 13.5-14 so am good there. Cruise is pretty rich at 12.5. This motor seems to want at least a whole number less A/F than what is always advised.
Just can't believe I have to jet this rich to run. AM I MISSING SOMETHING IN ALL THIS? Or am I on the right track and screw the logic?
Here are a couple of photos of the test run plugs (apologies for bad focus but best I could get my cell phone to do):
