winstoninwisc
Taint easy livin free,season ticket ona 1wayride
hello all , hope your summers been better than mine . I spent 2 years waiting to build my 360 la motor , We got it in and broke the motor in had 7 hours tops on motor and in 2 minutes the valve train /roller rocker adjustment studs backed out and took out motor .UN FREAKING REAL. some how some 1 tried to rethread 3 rockers and adjusters popped right out taking out pushrods and valve train .
So here is my new delema ; builder is taking 2/3rds responsibility ,but I did supply the rockers . Time for a rebuild again. I am asking for HELP and OPINIONS HERE ?? Ok hughes cams has there roller rockers on sale for$ 540.00 , and Harland sharp has theres on sale for $639.00( just to let guys know) , I am looking for a reference if any 1 has used either of these 2 sets on sale if any 1 has used or recommend 1 or the other ?
The Harland sharps are a needle bearing fulcrum , and the hughes are not and dave at hiughes has rite ups and is telling me , on needle bearing fulcroms being a problem spot , being a weak spot on the bottom taking so much pressure that the bearings tend to break right under the shaft at the holddown . Is this a SALES PITCH or a real problem ??
#2. I am still thinking on using the Comp cams k20-225-4 and lowering my lift a little from the 545 where I was and going to a closer to 240 duration because its a street car and wont see a track but 1nce or twice a year and I do not have headers and now cant afford them for sure with the rockers granading the motor .
On top of all that we had the bad storms here , We just got basement water and some tree damage , But with my hip and back problem I just didn't need this motor problem as well . I am running hydro;ic flat tappit lifters , 995 duel springs , but just really cant understand what happened when they worked fine on my 340 for last year until we pulled the motor . I was wondering if the roller didn't over ride my valve stem and caused it ???
if we over looked a pushrod not sitting in the pocket right . what we blue printed looked ok , they seemed to ride centered but weather it was mechanical or human error
im not experienced enough to know .but its pick a new valve train time and with some input mabee it will go better this time , We didn't find any damage in the new RHS HEADS , but do wish I had bought them thru brian at imm than buying from indy for more $ than brian quoted me . here is my setup give me your thoughts on name brand and cam there is 6 or 8 guys you know who you are I hope you will reply
4.030 K B hyper pistons , RHS HEADS 62 cc , , 10,2 static comp , 165-170 psi , street performance , 3-3200 stall , m1 intake , 650 dp holley right now , No headers 65 BARRACUDA 3000 lbs , 9"x27" tires , 3;23sure grip , pump fuel , hydrolic flat tappet , 3 speed auto manual cheeta TSI built tight gears trans , 1.5 unknown roller rockers yet ,
looking for a hot street type cam .
please give me your brand opinions comp cams , hughes , mopar performance racer brown ??? and your lift and duration or special grind #s , and wich set of roller rockers you pefer the hughes or the Harland sharp or another and its a LA motor and no roller lifters . please give your thoughts on what may have happened , and wich wpould your next cam be with this combo . thanx all and have a safe 4TH HONAR THE SOLDIERS AND PRAY FOR THE MIA . lets pick a cam for a hot street car have funn
