needed gas pedal for a 1962 valiant
VDART
Shulte Ks
Friend has a 1962 valiant-- the pivot part has broken at the base of the gas pedal where the molded rubber goes over--- I don't have any spares for this do any of you guys have one? I believe 1962-1965 are the same-- actually the cars with the rod style linkage should all work-- any help? thanks Lawrence
Interchange on this pedal is '60-'66 A-body with slant-6 engine and without '65-'66 factory A/C. So yes, that '66 pedal will drop right in.
I've got one also that should be the same. Came from a 65 Barracuda /6 car. If the one from pettybludart doesn't work out let me know.
Ken
Edison, NJ
Ken
Edison, NJ
I have one from a 2003 Toyota. It is supposed to make it accelerate like you wouldn't believe....sorry couldn't resist
