Check this out. I used it on a non Mopar recently. It is an adjustable voltage regulator. You can set it wherever you want to fine tune your gauges, or use one for each gauge if you want to do a little rewiring. No soldering required. You can stake the adjustment screw with a little paint to keep it from moving.
