whitepunkonnitro
This is the perfect cam and lifter package if you're looking to mount Magnum heads on an 85 up roller cam LA block, and retain the mechanical fuel pump.
This cam is also drilled for traditional LA oiling, so it can actually be used with any heads.
Mopar Performance #P5007548.
Specs:
Lift .482/.496
Duration 222/278 (216/222 @.50)
Centerline 119
Overlap 37 degrees
I've only got one of these available right now, but if there is enough interest I can have several more the week of the 19th.
Asking $150 plus the ride. PM me if interested. Thanks FABO!
Specs:
Lift .482/.496
Centerline 119
Overlap 37 degrees
