This is a subject that has been brought up many times here. Thought I'd pass on my personal experience. Yesterday after almost 4 years I finally got to drive my BB Demon, though it was only out of the garage. I've done many changes to the car electrically, ammeter bypass, running a Denso alternator and a FBO ignition module. I purchased all new wiring and modified the harnesses for my needs. Removed the voltage regulator wiring, bypassed ballast resistor etc. During the course of winter I rebuilt the steering column. New key tumbler, ignition switch, turn signal switch and key in buzzer switch. All name brand components Standard Motor Products and NOS Mopar. So here's the meat of the story. I prime the carburetor put fresh gas in the tank and check all fluid levels, climb in give the gas a couple pumps and crank, it fires almost immediately. Till I let off the key then it dies!! So I'm like oh crap, all the mods I've made what could this be, I used the wiring diagrams, double checked everything with a Digital ohm meter when I made the changes. So I'm thinking about the issue and I know it's firing in start. I jumpered battery to coil + crank it and all is good. Starts fine continues to run when I let off key. Just gotta remember that turning key to off does not shut car off. So I start digging into the problem at hand. I only have the dash frame in the car so I start simple. Check voltage to ignition switch, good. Back probe switch connector on out put for ignition 1, switch on, no voltage. Now this is a brand new switch, but there's a problem. So I disconnect connector ohm out red wire to dark blue wire, infinite resistance. Jiggle key around, no change. Here's the moral of my story, that name brand ignition switch that's brand new is defective. So don't always "assume" that new part is a good part. Sorry so long winded, just an experience I had and wanted to pass along.
