new TO bearing noise
Darren
ontario
Hey guys I just installed a new mcleod clutch kit plus new pilot and TO bearing. I just started the car (68 Cuda 383 ) and when I push in the clutch I get a little squeak but when the car warms up it goes away. Are these TO bearings greased from mcleod? Does anything have to break in? Any ideas? Thanks
I am pretty sure it was making it only when the clutch pedal was pushed to the floor only.... I just went to start it the was no noise ( but engine was still warm) but I will try it later on tonight when the engine is cold.. thanks
If it is a problem, you will hear some noise come back....TO bearing noises are pretty obvious if you pay attention.... as it seems the OP is.
Just went out to try the car and really smooth no noise... but I will keep a close eye (ear)on it.. thanks
