Regulars on this forum may recall a week or so ago I posted about suspected fueling problems as the 417 stroker I have was idling poorly. Well after a few day of back and forth here the car idled and ran great. Well after taking a neighbor couple for a super fun ride Sunday it would not start. Upon checking the carb was definitely getting fuel pumped into the primary barrels so I checked the ignition - no spark at all. I removed the coil and noticed oil leaking from it. On the way to work took it to an auto part store they - told me it was good. I suspected not. On the way home I upgraded my multi-tester and the old coil was out of spec. Replaced the MSD PN 8202 coil with a coil for a stock 340 (all they had). Still no spark (as confirmed with my new spark plug tester in place of my old school grounding method).
Checked the distributor, it looked good except the rotor had white dust all over it, which I cleaned with no effect. Any ideas on what to do next? We were hoping to take the car to a local show tomorrow but I guess not.
One final clue - when the car was idling poorly it also had a very slight surge at constant throttle, +- 50(?) RPM.
Any ideas?
Any ideas?
