Gublakhan
Active Member
Hello All
I'm new to this site and was hoping you all could point me in the right direction. I have a 66 Dart Slant 6 and I recently replaced the dash and engine wire harnesses. I was able to start it once for about 10min -- everything seemed to be working, then I shut it off. I tried to start it again seconds later and nothing. No power to the interior.
I've tested the battery and seems good. I tested the relay, starter and alternator and they all seemed to be getting voltage. I can crank the motor by using a screwdriver and jumping the lead and solenoid posts, but it won't start. When I try to start the car from the inside there seems to be no current from the ignition switch. I've tested the ammeter posts and they seem to be getting current. My thoughts are that I burnt the ammeter, or the neutral safety switch has gone bad, or worst, the welded splice off the black ammeter wire is not working. Does anyone have any good suggestions regarding testing and where to start??
Thanks for you help!!
