Non AC belt lengths or part numbers 318
C2ndLTpigeon
Mopar or no Car!
Indio California
Hello,
I'm looking on removing the ac from my 1973 Valiant with a 318. I am doing it the right way with the correct pulleys. 2 grove crank and correct wp pulley. I wanted to see if anyone might have either the size/length of the belts? Alt,fan,crank and PS,Crank.
I usually use Gates belts.
Thanks
If you're using the factory non-A/C pulleys, you should be able to order them by a 1973 non-A/C 318 application.
