gts4fuji
Also, since I'm on hold finishing up the head & cam swap until I source out the non-AC pulleys, I decided to do some masking & detailing of the block. I figured since most of the junk was out of the way & those bright, freshly pained 302 heads were bolted on, I better clean up what I can. So I masked everything off & coated with a couple of coats of primer & then a couple of coats of Chrysler Blue. It didn't come out too bad I don't think. Here's a shot of the original bay, followed by the initial clean up, then the head swap & then some shots of what it looks like after today's fun. Kinda cool to see the evolution.
Saetun in one of your photos of your engine. You still had a Heat Stove on the driver side exhaust. Did you save it by any chance? am trying to restore my 340 back to original.
GTS4Fuji
