standup303
Hey all, first time ever I had to get the car towed home last night. Just got a new carb, torque converter and from 3.23 to 3.91 in the rear. This was the second drive since the new parts. Car was stumbling from 3,200-4,000 but overall running good. Pulled in a parking lot and it just shut off. Has refused to start since.
I can physically see fuel squirting into the venturis while applying throttle. Just got 1/2 tank fresh gas. I popped the coil wire off the distributor and held it close to a bolt on the motor while having someone turn the ignition over. Got 1 pretty weak spark on multiple cranks. So not getting spark I would say.
I had a spare ballast resistor so swapped that. I’m getting 11.9v on the input side of the ballast and 6.5 on the output side, key on, not cranking the ignition though. When it’s cranked I’m only getting 8.5 at the secondary side and at the coil.
I had an older coil I knew was working before, I hooked it up and still didn’t do anything. No spark on the coil wire holding it to a bolt. It started to fire once or twice for a split second but didn’t go.
Not sure where to go from this point. ECU?
I was reading the brown wire on the secondary side of the ballast is supposed to be a “start” circuit and put a full 12v to the coil, and only had 8.5v. But have also read the coil only needs Between 6-12v for start?
Any help would be greatly appreciated.
