Not-SFI Approved Flywheel?
ckj688
Massachusetts
I gave up on finding a used flywheel so I've been on SummitRacing looking for a flywheel...I'm settling on this...BUT it says it's not-sfi approved...am I going to run into any problems @ the track?
I read this on the site:
Performance and SFI-approved flywheels must be used with performance clutch discs only. Use of a stock-style clutch disk with a performance flywheel will often result in insufficient operating clearance between the disc hub and flywheel bolts.
I'm assuming I'd be okay because the Centerforce Dual Friction clutch I ordered isn't "stock"...
Thanks!
Craig
did you take a look with ma mopar
brother but one 2 years ago from chrysler dealer here in town
