Oil accumulator line size?
Bad Shrimp
Tacoma, WA
Purchased Moroso Oil Accumulator and hardware. When I first read the instructions they said "use -8AN stuff, it will be sweet".
Now that I have bought all -8AN line and hose ends, I just re-read the instructions and it now says "All oil lines should be made up of -10(5/8 ID) hydraulic high pressure hose".
I'm assuming the -8 stuff that I bought will reduce flow etc, but is it a deal breaker? If I use the -8 gear will I be creating a large problem for myself? (440 engine)
(my plan was to run the -8 hose/-8 hose ends from oil pump->remote oil filter->oil cooler->oil accumulator->back to oil pump etc. etc.)
Thanks in advance
Bad Shrimp
I use -10AN. Remember if there is a problem, you want the restriction to getting the oil back into the system to be the passages in the block... Not the line from the accumulator.
I may be learning something here. The accumulator is to keep oil pressure in the event of a problem? I always thought they were to prevent dry start up.
Thanks for the replies. Looks like i'm going to need to switch it over eventually, prolly sooner than later. I guess I should read instructions a lil' more often rather than "just look at the pictures" lol.
