Oil filter adapter gasket?
MB43
No
There's a gasket that goes behind the plate that attaches the oil filter to the block, yes? Any idea where I could get that from? I've checked Summit, Jegs, Mancini, etc, but can't find it. But then again I'm not sure what it's called.
This is for a standard oil filter, not a right-angle one.
I know they come in a FEL PRO overhaul gasket kit.
I got mine at the dealer. It has been some time ago when I got it.
Yes, it is the same one, but if you have just the plain round one, you will also need a small round one to go under the adapter nipple itself.
Ok, cool. Thanks.
