68valiantbb
Active Member
hello all .I have a 68 valiant with a 400 .my oil pan is hitting the center link on left turns. what is the fix for this . any help greatly appreciated .thanks
I have the 187 pan and pick up mentioned above, if you need it. also you can put 3/8" or 1/2" shims between the k frame and frame rails, will give you that amount of clearance. the factory did it on the 68 hemi superstock drag cars!-----bob#187 or #699 from a C-Body. Idler may still contact the pan at the point circled below but can be massaged slightly. A #971 is supposed to work too but it doesn't have the notch. It may be more readily available (new?)
3/4 nuts work perfectly for that, and look nice. This lowers steering suspension in reference to the engine mounts that are hard on the frame rails. Applies a slight torsion bar load though.I have the 187 pan and pick up mentioned above, if you need it. also you can put 3/8" or 1/2" shims between the k frame and frame rails, will give you that amount of clearance. the factory did it on the 68 hemi superstock drag cars!-----bob
