oil pressure guage installation help!!!!
arto321
New Member
[FONT=&quot]when I bought my 74 dart it already had an oil pressure gauge installed but I decided to buy a new gauge kit so I removed the oil pressure gauge and pulled the plastic tube that connects the gauge to the engine from the inside of the car thru the firewall and now I can’t find the oil pressure connection that is supposed to be on the engine what should I do? I’m really new to this please help[/FONT]
The oil pressure switch that you are looking for screws into the top of the block between the back of your intake and the firewall, kinda hard to find. If I were you, I would go to the auto parts store and buy the tee fittings so that you can install the stock sending unit along with the new line fitting. This will allow your dash light to work as normal along with your new gauge.
Good luck and welcome to the site!!
