First off I want to thank everybody for input and there guided service of helping rebuild a motor. So Good news the motor runs great smooth as can be. Now, I put it in gear today and went to take it around the block nice and slow. As i was sitting at the stop sign the oil pressure dropped down to about 5lbs. Does anybody have any suggestions on what to do?
I still have to take the timing light to the timing because you can tell the timing is off but, timing doesnt effect the oil pressure at all or does it when it brings the idle up.
When i start the car and leave it in park the i am pumping 50lbs plus, when its in drive and stop sign i loose pretty much all that oil pressure. Give the gas it has no problem picking up pressure.
I am just looking for input and advice in this matter. Thanks for the help again and I hope its a small problem
