Mikes geometry correction. PRW shafts and roller tip rockers. It leaked really bad under the shims to start with. I started freaking out thinking I was suffering from the dreaded Speed Master Pedestal problem. They are actually PROMAXX heads. I loosened the shafts and clock the shafts better to eliminate exposure of the oiling holes There is a lot of tolerance there. Probably an eight of inch of rotation. Okay , got that fixed but now I have some significant leakage under some of the retaining bolt washers. I'm thinking some bigger washers may take care of this as the retainer holes have been chamfered a bit to relieve stress. I will be contacting Mike in the AM so no need to tag him.
So here is the question. I am hammering this engine hard with the oil pump, 70 pounds of high volume oil constantly to the head. Am I simply over powering it's ability to contain the oil? There is a lot of oil flowing out of those shaft bushings. Once I marked the balancer to the location of the camshaft oiling holes, on the engine stand, I was able to rotate the engine enough on the stand to pound the oil to it without worry of spilling.
