VonCramp
It looks like I will need to replace my oil pump driveshaft and bushing. I discovered my oil pump driveshaft is galled causing the distributor to wiggle around while cranking. Is it possible to remove the bushing and replace with the 340 still in the car? If not, anyone have a 12 gauge shotgun or some C4 I can use? I am ready to put this '69 Cuda to rest. I can sincerely say this car has been the biggest pain in the *** I have ever worked on.
