Oil zddp ?
I take a sip of whiskey. I take a sip of pepsi. It mixes in my belly. Same results. I still get drunk. Lol
In the end, nobody changes their ways. I have no problem with multiple ways of getting the same job done.
Where did I disagree?
I don't really care for VR1 but it's a damn sight better than oil with no zinc in it.
My point is I was mixing 2 stroke oil in 1972. It has to be right or you eat parts and chase the tune up.
Much easier to add an additive to oil than remixing 2t oils.
LOL.... read post 68. you hit the disagree button. I thought it was funny, because I listed two facts. 1). I have a Duster on VR-1 and 2). that I liked it (so far). So I asked if you disagreed with the fact that I have a Duster on VR-1 or the fact that I liked it?
Just jok'n/pok'n.... :poke:
Damn, why that **** is on the right side of the screen I'll never know. I had to hit that thing by accident. Had you not pointed it out I would have never know I hit it.
Wonder how many times I've hit something over there and not known it. I very rarely hit the disagree button. If I don't like something enough to hit that button I type it out. So I fixed it for you.
BTW, how did you know I hit the disagree button? I didn't even know I did it. Damn **** technical crap.
That's just funny .....
:rofl:Oh, you can move your curser over them and see who agreed/disagreed. It will list them all for ya. Also, I get this red "alert" telling me when somebody agrees, likes, dislikes, or quotes anything of mine. You get the same I'm sure.
Who knew besides you? I had no idea. I have never seen an alert. But possibly I wouldn't know one if I did see it.
I'm in the wrong generation for sure.
picture ones show hole in seal....
picture two shows zddp being added to 5 qt jug of oil
picture 3 shows cap back on 5 qt jug of oil after being shaken ....
Z written on cap to let me know that the zddp has been added...cause same oil brand is used for pick ups...and other vehicles not needing zddp...
whole time took probably 5 minutes since I left the small 4 oz container drain while I was doing other things...multitasking ....
Absolute classic.
I just found this article about motor oil , interesting reading.
Engine Oil Mythology
Thanks to Bob Olree – GM Powertrain Fuels and Lubricants Group
GMPT – Fuels & Lubes
Myths are ill-founded beliefs held uncritically by interested groups. Over the years there has been an overabundance of engine oil myths. One was that the only good oils were oils made from “Pure Pennsylvania Crude Oil.” This one got started before the Second World War when engine oil was crude oil with very minimal refining, and crude oil from Pennsylvania made better engine oil than Texas or California crude. With modern refining, almost any crude can be made into good engine oil.
The next myth was that “modern” detergent engine oils were bad for older engines. This one got started after the Second World War, when the government no longer needed all the detergent oil for the war effort, and it hit the market as Heavy-Duty oil. These new detergent oils gave the pre-war cars, which had been driven way past their normal life and were full of sludge and deposits, a massive enema. In some cases bad things happened such as increased oil consumption – the piston rings were completely worn out and the massive piston deposits were the only thing standing between merely high and horrendous oil consumption. If detergent oils had been available to the public during the war, this myth never would have started.
Amazingly there are still a few people today, 60 years later, who believe that they need to use non-detergent oil in their older cars. Apparently it takes about 75 years for an oil myth to die.
Then there is the myth that new engines will not break-in on synthetic oils. Apparently there was an aircraft engine manufacturer who once put out a bulletin to this effect. Clearly the thousands and thousands of cars filled with Mobil 1 as factory-fill, which have broke-in quite well, should have put this one to rest. However this one is only 40 years old, so it has another 35 years to live.
All of these myths have a common theme; newer oils are bad. And this brings us to the latest myth – new “Starburst”/ API SM engine oils are bad for older cars because the amount of anti-wear additive in them has been reduced. This one has gotten big play in the antique and collector car press lately. The anti-wear additive being discussed is zinc dithiophosphate (ZDP).
Before debunking this myth we need to look at the history of ZDP usage in engine oil.
ZDP has been used for over 60 years as an additive in engine oils to provide wear protection and oxidation stability. Unfortunately, ZDP contains phosphorus, and phosphorus is a poison for automotive catalysts. For this reason ZDP levels have been reduced by about 35% over the last 10-15 years down to a maximum of 0.08% for “Starburst”/API SM oils.
Zinc dithiophosphate was first added to engine oil to control copper/lead bearing corrosion. Starting in 1942, a Chevrolet Stovebolt engine with aftermarket copper/lead insert bearing connecting rods was the standard oil test. The insert bearings were weighed before and after test for weight loss due to corrosion. The phosphorus levels of oils that passed the test were in the 0.03% range.
In the mid 1950s Oldsmobile got in a horsepower war with its Rocket engine against the Chrysler Hemi. Both companies went to high-lift camshafts and both got into camshaft scuffing and wear problems very fast. There were three solutions. Better camshaft and lifter metallurgy, phosphating the camshaft, and increasing the phosphorus level from ZDP up to the 0.08% range. Another outcome was a battery of industry wide “Sequence” oil tests. Two of theses tests were valve-train scuffing/wear tests.
Knowing that this higher level of ZDP was good for flat-tappet valve-train scuffing and wear, some oil companies dumped even more in thinking that they were offering the customer even more protection. However it was soon learned that while going above something like 0.14% phosphorus might decrease break-in scuffing, it increased longer term wear. At about 0.20% phosphorus the ZDP started attacking the grain boundaries in the iron, resulting in camshaft spalling.
Later in the 1970s, the ZDP level was pushed up to the 0.10% phosphorus range as it was a cheap and effective antioxidant, and increased antioxidancy was needed to protect the oil in Cadillacs pulling Airstream trailers from thickening to the point of not pumping. Recently, the need for this higher level of ZDP for protecting the oil from thickening has been greatly reduced with the introduction of more modern ashless antioxidants that contain no phosphorus.
Enough history, now getting back to the myth that “Starburst/API SM oils are no good for older cars. The argument put forth by the myth believers is that while these oils work perfectly well in modern gasoline engines equipped with roller
camshafts, they will cause catastrophic wear in older engines equipped with flat-tappet camshafts.
The “Starburst”/API SM oil standards were developed by a group of OEM, oil additive company, and oil company experts. When developing any new engine oil standard the issue of “backward compatibility” always comes up, and indeed the group of experts spent a lot of time researching this issue. Various oil and additive companies ran “no harm” tests on older cars with the new oils. No problems were uncovered.
The new specification contains two valve-train wear tests. One is the Sequence IVA Test which tests for camshaft scuffing and wear using a 2.4L Nissan single overhead camshaft engine with slider finger followers. The wear limits were tightened from the previous oil specification which contained a phosphorus limit of 0.10%. The second is the Sequence IIIG Test which evaluates cam and lifter wear. A current production GM Powertrain 3.8L engine with the valve train replaced with a flat tappet system similar to those used in the 1980s is used. The only reason that this test engine uses this older valve train design is to insure that older engines are protected. All “Starburst”/API SM oil formulations must pass these two tests.
In addition to the protection offered by these two valvetrain wear tests and the new testing which was conducted on the formulations containing lower levels of ZDP, a review of the knowledge gained over the years in developing previous categories also indicates that no problem should be expected. The new “Starburst”/API SM oils contain about the same percentage of ZDP as the oils that solved the camshaft scuffing and wear issues back in the 1950s. They do contain less ZDP than the oils that solved the oil thickening issues in the 1960s, but that is because they now contain high levels of ashless antioxidants that were not commercially available in the 1960s.
The oil’s ZDP level is only one factor in determining the life of an older camshaft or a new aftermarket camshaft. Most of the anecdotal reports of camshaft failures attributed to the newer oils appear to be with aftermarket camshafts. Breaking in extremely aggressive aftermarket camshafts has always been problem. The legendary Smokey Yunick wrote that his solution to the problem was to buy multiple camshafts and simply try breaking them in until he found one that survived break-in without scuffing.
Despite the pains taken in developing special flat tappet camshaft wear tests that these new oils must pass and the fact that the ZDP level of these new oils is comparable to the level found necessary to protect flat tappet camshafts in the past, there will still be those who want to believe the myth that “new oils will wear out older engines.” Like other myths before it, history teaches us that it will take about 75 years for this one to die also.
February 13, 2007
The issue with the above post is the tests they used. Not likely did either have a seat pressure of more than 80 pounds.
Also, the lobes tested are very slow lobes.
They also don't have a rocker arm.
This all makes a difference.
Has anyone done a more appropriate test?
Meanwhile I think I'll keep on running at least 1000 ppm (0.10%). The extra few bucks isn't a big deal, and with enough support on this forum I can handle the mixing problem ;)
Agree...plus the fact it's from a GM guy and nobody has yet to explain to me what the hell Dexos is! Including people from GM!!
With that said, those of you using Mobil 1.....be sure you're using a racing flavor with enough ZDDP. My buddy lost a solid flat tappet Mopar cam after 1000s of miles while using Mobil 1. He's now running a Comp solid flat tappet and Brad Penn. I'm running a Comp solid roller and Brad Penn.
Yup, been tested to death.
The zinc was reduced because the HRT cam became the norm and it doesn't need the zinc, which kills catalytic converters.
I know why it was reduced... (and isn't it the phosphorus, not the zinc?).
What I'm asking is if anyone has actually run test engines with Mopar-sized flat tappets and lobe designs, and more aggressive springs (say 130 seat, 350 nose), with varying levels of zinc.
There's a lot of anecdotes along the lines of "I never lost a cam until I used VR-1/didn't add the zinc/bought lifters from Comp", etc. etc.
I'm betting thousands of flat tappet cams have had long healthy lives
running regular 10w30 Dino oil with 800 ppm zinc or whatever.
this is true to a point. I called Valvoline company itself. They said if a car already has 60,000+ miles on it, the extra zinc isn't necessary. But new cams/lifters, it's very critical, especially the first few thousand miles while things continue to break in.
Of course, when you start adding high pressure valve springs, and higher lift cams, it all becomes that much more critical.
Hell no, I wasn't going to test that!
Unless it was dead stock I always run zinc in the oil. BUT BUT BUT....too much zinc is a power killer. I know the VR-1 was anywhere for 8-15 HP down to other oils. So we're the other oils with zinc over 1000 PPM, IIRC.
It's just too expensive to test what your asking. Unless you have fat pockets and want to prove something most people won't believe anyway.
When I think about a tiny container of ZDDP dumped into a valve cover hole and whatever tiny bit of it making it down to the 6, 7, or 8qt pan. Then starting the engine, letting it run long enough for the oil pump to circulate and mix the oil enough to evenly mix in that ZDDP additive and of course carry the rest of it down to the pan.....
Does it sound ridiculous to you yet?
Buy the oil you need. Pour it in, start it, run it.
Gasoline has additives that are added this way into the huge underground tanks. They don't carry around 87, 89, 91, and 93 in the trucks. Oils also have additives from the production that have to get mixed in, so why not an additive from the end user. Personally, I didn't do it, I used Valvoline VR1 in my '80 Aspen, but nothing wrong with adding it in yourself.
Mobil1 15W50 has over 1200ppm ZDDP, and it's available off the shelf at O'Reilly's.
I don't like additives because 1) you forget, and 2) when you top off the oil you don't get any.
I'd like to use that in my '68 383 as I have had good exp with all mobil 1 ...have you ever thought it was a little heavy in your experience using it?.
It may not be heavy for his setup. My last 440 ran 20/50 with normal pressures.
