$6950 is pretty cheap for what that motor is.
When you get you quote, ask him how much to compleatly build it for you and dyno it. It will be more then that!
It's more fun to get your hands dirty and do it you self!
http://www.mrlperformance.com/
My build better not even be a 4th of the cost of his motor. At least it better not be.
if you want to see some costs...check out the Carcraft article...480 hp stroker small block...
http://www.carcraft.com/techarticles/ccrp_1006_small_block_mopar_stroker_dyno_test/viewall.html
If you have some usable items for your build already...that will chop the cost down a bit...but it's still a costly build.
Paul
Which edelbrock heads you have, the open chamber 340 version or the closed chamber 360 version?
They are closed chamber, wasnt even aware Edlebrock made an open chamber for the small block mopars.
Are you telling me that the closed chamber heads 60075 which are 63cc that I have maybe the reason for the bent rods? They been on the car for 5 years. The 65cc are the 60179.
