GregL
Hi Guys, Can I get some feedback on this car? Your ideas if think this is reasonable?
Thanks, Greg
1971 340 Plymouth Duster
Thanks, Greg
Noticed the same, that apron has had some hammer work. The rear bumper is over to the right. The sloppy seam sealer work and spatter paint is probably hiding some more rust. I would want to get under it and poke around with an ice pick. Could find a nicer example for that money.The fenderwell around the tag looks wrinkled - car was hit sometime, maybe. Check the frame. between 5 and 8k, methinks.
Run from that one!Ouch! You guys are tough!![]()
Yep, probably stuffed the rail a bit. That might be why it's sitting higher on that side. I thought the quarter looked a little blown out right by the bumper. He's got whatever piled up over the left rail/trunk floor so you can't see it. Maybe a buckle.Owner says it suffered a relatively small bonk on the LR quarter where the primer is.
I would disagree your car looksI'd bet I'd be lucky to get $10,500 for mine, and I have that much under the hood, alone.
I disagree your car looks greatI'd bet I'd be lucky to get $10,500 for mine, and I have that much under the hood, alone.
In pictures... It actually needs front floor pans, trunk pan redone, drip rail work, lower quarter patches, rocker work, and paint...Which illustrates my point about him going to see it in person.I disagree your car looks great
I agree but as time goes on there's no telling what these cars will be worth as they become scarce with every passing yearat 5100 this guy is gonna have that **** box for a while.. 1972 Plymouth Duster
