ScampMike
Despicable Damn Yankee
yea, they can a b***h to work on even with a small block in there.. and I agree, no cutting!! I wish I was nearby bud, you need someone to assist!Be nice if it had room like my camaro.I don't wanna cut on the car.
Thanks.I'm gonna fix that bolt problem.I'm cutting the end of the header and using a v clampyea, they can a b***h to work on even with a small block in there.. and I agree, no cutting!! I wish I was nearby bud, you need someone to assist!
if you're going to make it straight pipe to straight pipe - have you tried those band clamps?? used correctly they are the chitzThanks.I'm gonna fix that bolt problem.I'm cutting the end of the header and using a v clamp
I don't see why a high dollar header has the bolt holes in the dumbest spotif you're going to make it straight pipe to straight pipe - have you tried those band clamps?? used correctly they are the chitz
I have the same basic thing with my headers on the small block - two bolts low and even from side to side - easy peasy, one on top on of each header flange -- horrible to get at - stoopidrasafrakastinkin'#$%^*I don't see why a high dollar header has the bolt holes in the dumbest spot
