Over heating 66 Dart
Heating / Cooling / AC
  1. 66 fish
    66 fish Member
    13
    2
    Aug 27, 2014
    Rainbow City Alabama
    Local Time:
    3:32 AM
  2. 66 fish
    66 fish Member
    13
    2
    Aug 27, 2014
    Local Time:
    3:32 AM
    The way I filled the radiator was to put about a gallon of pure coolant in the engine (cold) and a gallon of water. Then I would start the engine and begin to fill the radiator until it was about an inch above the rows in the radiator. I would keep the engine running until it came up to temperature and fill the radiator with 50/50 mix until it remains at about an inch above the rows then put on the cap. Thanks
    • Like Like x 1
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      38,599
      20898
      Jan 18, 2006
      Iowa
      Local Time:
      3:32 AM
      How hot does the engine get? Does it actually overheat and boil over? Yes it sounds like a fan/shroud issue. The original radiator would have been a 19" radiator and the HP273 radiator would have been a 22" AC radiator. The aluminum radiator you used should cool it fine with a good fan and/or a shroud.
      • Like Like x 1
      • 66 fish
        66 fish Member
        13
        2
        Aug 27, 2014
        Local Time:
        3:32 AM
        I probably need to change my name on here. I used to have a 66 Barracuda and that is when I used the 66fish name. I no longer have the Barracuda. But I have named my 66 Dart Clyde. So, I can get in my Dart named Clyde and ride!!
        • Like Like x 1
        • 66 fish
          66 fish Member
          13
          2
          Aug 27, 2014
          Local Time:
          3:32 AM
        • toolmanmike
          38,599
          20898
          Jan 18, 2006
          Iowa
          Local Time:
          3:32 AM
          66 Dart, same thing when it comes to radiators and cooling.
        • toolmanmike
          38,599
          20898
          Jan 18, 2006
          Iowa
          Local Time:
          3:32 AM
          I have overheating issues with my 70 Swinger. Yes it actually blow's coolant out all over the place. It has dealer installed A/C but they used the small 19" radiator. :BangHead: Bob at Glen Ray Radiators is going to build me a 22" so the issues should be gone.
        • 66 fish
          66 fish Member
          13
          2
          Aug 27, 2014
          Local Time:
          3:32 AM
          The radiator I now use is a 22" radiator. I can't seem to find my receipt so I don't remember the name of the radiator company I got it from. But it is an all aluminum welded radiator that has the exact appearance of the original radiator. It has the rounded tank on top and if it was painted black, unless you was looking for numbers or something it would look exactly like the original. I got the radiator off ebay. It is a 2 row radiator. My brother's 65 dart has the same set up I do and he has no shroud. But he has the original radiator. Although his is a 4 speed. I don't see how that can have anything to do with the overheating. However, I just remembered his has the dual point distributor, this is an ah ha moment for me. Maybe the timing is not right. We did set the total timing to 40 degrees. I wonder if the electronic ignition is not working with the engine properly? I don't know. I'm not a mechanic, my brother is. I was always the mechanic's helper! I understand how much of the mechanics work, but I am no mechanic!
        • SSVDP
          SSVDP FABO Gold Member FABO Gold Member
          4,189
          3844
          Feb 6, 2009
          Clarksville, Tn
          Local Time:
          4:32 AM
          The ignition timing could be part of your issues.
          Otherwise it sounds like you need more air through the radiator when the car is not moving.
          I just sold a seven blade fan from a ‘66 273 and it would be interesting to see if just that would have solved your problems.
          And the auto trans cooler does put some additional heat into the cooling system that a manual trans does not.
        • 66 fish
          66 fish Member
          13
          2
          Aug 27, 2014
          Local Time:
          3:32 AM
        • 66 fish
          66 fish Member
          13
          2
          Aug 27, 2014
          Local Time:
          3:32 AM
          I have installed a 7 blade direct drive fan. The air flow through the radiator is much greater now but the same issue is still occurring. The fan is still about an inch and a half away from the radiator. I will do more looking at the timing. I am just stumped!
        • 66fs
          66fs Well-Known Member
          3,891
          775
          Sep 9, 2009
          Greenwood, South Carolina
          Local Time:
          4:32 AM
          273 HP auto never runs hot, 1.50 inch between radiator and fan. 300,000 miles
