P/S box question
Cameron1038
Rio Oso, CA
Hello,
I have a 73 Swinger with /6 and power steering. I am going to be putting in a 318 w/ the 73+ small block k member. Can I use my current power steering box? Will it bolt up the same?
Thanks
Cameron
Hello,
Thanks
Cameron
Yep, same power steering box, idler, pitman, centerlink.
The power steering pump will need different brackets.
A hunting you will go, a hunting you will go. Hi ho a merry o, a hunting you will go!
Sorry I couldn't resist.....I would check the sells ads here and you can order aftermarket new ones (but those won't be stock looking for the most part).
