Paint wheelwells?'s
HemiPar
Kentucky
One of my winter projects is to sand and paint the wheelwells on my Swinger. I was planing to strip to bare metal, epoxy primer and paint semi gloss black. My ? is, should i use sealer before i paint? Should i use undercoating? what are most of you doing? Thanks for reading.
Epoxy is a sealer so the only consideration there is that you shoot your paint within the topcoat window, check the tech sheet for that. No big deal if you miss the time frame, you just have to sand or scuff it to get some bite.
