Panel lights flicker, gauges go to max
wafastr
Active Member
north Idaho
Newbie here, thanks for all the advice in advance. 1970 Swinger headlight switch works great except when the rheostat is turned CCW so I can see the panel in the dark. That is when the fuel gauge and temp gauge go to their extreme max positions. When I rotate the switch CW to turn the panel lights off, they return to normal. I thought my car was heating up as I drove to work the other day. It seems that excess voltage is going to the instrument panel. The headlights and taillights are unaffected. Hopefully just a switch replacement. Any advice?
The 1 circuits aren't directly related so,
There has to be a problem in the wiring harness or nore likely on the inst' panels printed circuit board.
Sounds like a ground problem in the cluster, to me
