Part # for points with prestolite dual point distributor
Hey Ray, I'm back, received the parts thanks, check out the ground wire that I previously spoke about in my distributor
Needs a new one it goes from the lower plate to that hold down screw on the points. Without it the ground is going through the ball bearings.
Raymond at Halifaxhops is a great resource. I recently sent him my Superbird 440-6bbl DP Prestolite distributor for a complete checkup, restoration and new points/condenser. he personally phoned to completely understand what I wanted to do and then set up the advance curve (mechanical and vacuum) accordingly. Highly recommended.
Jim
This thread is old, but I need new dual points for my 273 commando. I keep getting big block points. What part number should I be looking for, and where can I buy the correct ones? Thank you.
Send Halifaxhops a PM he stocks the good ones. Get a quality condenser from him as well. All the new ones are bad quality. Keep your old ones for spares.
If you backread, Hoppy posted the Mopar part numbers. Any good parts store can change those numbers to what they sell. Their quality won't be there though.
