scott657
I am putting an Edelbrock performer carb onto a 360 cast iron intake manifold. Do I need an adapter? Also what gaskets do I need to accomplish this swap. As always thank you in advance
This....
EDELBROCK 2732 Carburetor Adapter Plate
you can put it on top of the TQ thick base gasket if you want. My intake had some of the material removed on the center divider to help match up to a square bore, so I don't know if your back barrels will be interfered with or not. set it on there and open it up before hooking everything up, and you'll know more. I used the above adaptor and worked great for me.
