Pick me a cam
Virtually stock with 19" vacuum. J.Rob
I wouldn't mind sacrificing a little vacuum to have a slight canny like as long as it's not gonna kill performance. I don't need 400lbft of torque at 1000rpm. Just enough to get it rolling
"Killing performance" is subjective. 400 foot pounds won't show up at any RPM-no matter the cam. J.Rob
The relatively short duration is no surprise w/a compression ratio that low, You've handicapped yourself with less than 9:1 squeeze, so that's what will be recommended by most
grinders. Yeah, You can go bigger, but it will narrow the torque curve.
I know. Was just making a point that I don't need tire shredding low end. Just strong mid range and something that pulls strong to at least 5grand without falling flat on its face like my current cam
Then get the Eddy RPM cam that goes w/the intake & run it, there's no way that cam is done by 5K, and it picks up by 2500...
