SSG_Karg
Enhanced member
Trying to track down the root of a vibration I've been having. Decided to verify pinion angle.
Car is 72 Duster with warmed up 318, 4 speed, 3.91 8 3/4, 002/003 S/S springs, 28" tire.
Checked angles with full weight of car on suspension at ride height. Currently transmission angle is 88* (or 2* down from level). Pinion reads 92.5* (or 2.5* up from level). I checked it with the Tremec app on my phone and it gave me the ok. Now, from what I've read here, this is about where I want the angles under load. So I'm thinking of adding 2* shims to lower the pinion angle to 90.5 (or .5* up) to get them closer to equal upon acceleration. Car is street car that is driven like a hot rod should be and gets half a dozen or so passes on the strip. Opinions on my pinion? Thanks.
