Hey all,
I was thinking of adding some more go fast goodies to my 360 over the winter and was considering a piston change from the factory dished pistons. All things being the same in the motor would you run the Badger b290 or the Sealed Power 405cp pistons. I already have a set of the badgers hung on rods.
I was planning on running an old erson .480 Hyd cam with 1.6 roller rockers. I may have the heads done with 2.02 valves also, but unsure of that since they only have less than 2000 miles on them since the motor was rebuilt last winter, with the 1.88" intakes.
your thoughts?
your thoughts?
