hey guys my my kb piston info sheet says to leave .0020 " .0025" for street use. Does this mean 2 - 3 thousands of an inch? thanks
2 to 2 1/2 thousands
I believe that means that the bore needs to be 4 to 5 thousands (.004 - .005) larger that the pistons diameter measured at the manufactures specs.
Clearance (.002-.00250)(one side) plus piston diameter, plus clearance (.002-.0025)(other side)
Keith Black designed the piston to be run in a tight bore. For street use you want .002-.0025". This is the difference between the piston diameter and the bore diameter.
Keith black pistons do not have off set wrist pins like stock the ones do to keep slap down. stock ones are off set about .090
So if i want presed fit wrist pins i got use my old wrist pins?
Is it possible they are designed for both? I just bought a new set of Speed Pro's for my small block build and they are for press fit OR full floating.
How do you make them preesed fit if the pins slide in the pistons so easy? Thanks
So if want my kb pistons to have full floating pins i would have to have the pin hole in the stock rod bored and use a bushing? Thanks
