gzig5
So can someone enlighten me as to why the oil rings have a hard time getting over a ridge but the top two don’t? I had to essentially eliminate the ridge or the piston would not come out
Either way it’s going in the bin. It would need at least 20 over to clean up from the ridge and I have no use for a 273. If someone else can use it great and I’ll take care of that in another thread. I’m pretty sure that my method of removing the pistons didn’t open the bores up much over where they would have with the reamer because I had to do it multiple times to get them to come out. I took light cutsAnd now;
because you didn't ridge-ream the block ............... and made a mess; you are looking at .060 overbore? instead of .040; Is that right? I mean jus asking for a friend.
Well, look at them. They are practically knife-edged, and not cast like other two, and have a big ol' spring pushing them against the cylinder walls. They get stuck in the worn part where the top ring stops and under the sharp metal step politely called, a ridge. To the oil ring, that ridge is practically a solid wall. Whereas the cast rings just bounce up and over.So can someone enlighten me as to why the oil rings have a hard time getting over a ridge but the top two don’t? I had to essentially eliminate the ridge or the piston would not come out
Now that's funny right there I don't care who you are. lolTap them hard enough so those pistons land at my front door!
Yeah just sand gently on top of bore.
Already have two 340's, don't need another. Thanks. I saved this 273 short block which had been sitting outside for fifteen years at least, from the scrapper and am just trying to save some parts others may be able to use. The crank and rods may or may not live again in the second 340 block I have.Or maybe you'd rather have a 340..... lol. But not giving that away...
Hell, you'd lose um. Least till the SprAng.
