Ok I did some searching around and have located a 67 center link to use in my swap back to original equipment ( have flaming river rear mounted power rack as of now). So it sounds like the center links are the same from 67 to atleast 72 CORRECT?? If I use that and get 68 pitman and idler arms or atleast a matching set of arms for a 67-72 I should be fine Right?? I see the 67 idler is expensive so I wont be using that type. I am having them cut off the steering and idler mount off the 67 donor K member because someone cut mine off when they put the power rack in, so I figure they should be a direct weld on and I hope they dont cause me fits. Does it sound like Im on the right track????
