please help me out! dropdown center link
63VALIANT*KISS
Eureka,Ca Humboldt
i have my 318 63valiant wagon and i was wondering if they make a v8 drop down center link my oil pan is sitting on my center link and rubbing. i tired to get it allighned they said no. i just replaced the front end with psc suspention they have none available.
You should be able to change it to the 68-72. I change the one on my 65 and I think they are the same for 63.
Later 67-72 and 73-76 centerlinks are too wide for the early A Bodies. You need one from an early A V8. I've heard that some slants got the dropped centerlink in 66 (the slant 66 Barracuda I parted out had the slant link).
You'll need the 64-66 v8 centerlink or shim up the motor mounts with some steel plates. About a 1/4" thick. This is what I did on a 62. Works great.
