You were DOING the impossible WITH the impossible FOR the unwilling.
Add in unbelieving. Ungracious would also apply.
I had hoped that someday a set of your high effort ported iron heads would end up at my shop for one reason or another. But I guess if the number of units in circulation is “zero”, the chances of that happening are mighty slim.
Is it possible that maybe a small part of the $5100 price tag was that you didn’t really want anyone to get their hands on a set of those heads?Cause like my plan was always to give that design away. I think I'll have my son bury all the STG V and 906 heads with me.
Possible? Without a doubt for sure!Is it possible that maybe a small part of the $5100 price tag was that you didn’t really want anyone to get their hands on a set of those heads?
If you sold a set, then what happened with them and who saw them would be out of your control.
Sounds like a good idea to scan those 340 cfm ports and convert them to an NC file for CNC porting. That might bring the price down to a level where people can afford them.
Nine years ago I looked into it. That was when we had test ports in Edelbrock RPM and Stealth heads flowing in the 350 cfm range. For me the cost was prohibitive and I was unconvinced that the program would remain proprietary.Sounds like a good idea to scan those 340 cfm ports and convert them to an NC file for CNC porting. That might bring the price down to a level where people can afford them.
Maybe buy a used tracer mill for much less?
Thank you for the suggestion. However a tracer mill is not quite sophisticated enough. But hang around, this is a fun place!Maybe buy a used tracer mill for much less?
New or used CNC machine at $280K?Thank you for the suggestion. However a tracer mill is not quite sophisticated enough. But hang around, this is a fun place!
New.New or used CNC machine at $280K?
It's not. Someone who's figured out how to do something nobody else has deserves proprietary treatment. You wanna do what they do? Pay them to do it for you. Right?I don’t see how ripping off a members or any bodies hard work is a good thing.
I didn't word it correctly my bad, the message I meant to come across is someone that does have a CNC machine copy the head on the 2 porters behalf and make them readily available. Proceeds would go to both the CNC operator and the original porter. By all means not to ever rip off anyone, but to increase the availability. I apologize if my statement came out wrong the 1st timeI don’t see how ripping off a members or any bodies hard work is a good thing.
Another option is for the end user to figure it out for themselves. I promise you, after the YEARS it will take, you would have a new found respect for those who've gone before you. I get what you're saying. The thing is, these guys have years of experience......that span three generations. Have you seen some of Jim's work on here? Try searching "low compression 440" and put in "IQ52" for the username. You'll be blown away by their numbers if you've not seen it.I didn't word it correctly my bad, the message I meant to come across is someone that does have a CNC machine copy the head on the 2 porters behalf and make them readily available. Proceeds would go to both the CNC operator and the original porter. By all means not to ever rip off anyone, but to increase the availability. I apologize if my statement came out wrong the 1st time
pfhhhhtttttt.......specially with cast iron! It's so costly in tools it's pathetic! Take that money and get some aluminum heads and have them worked. You'll likely come out cheaper.Nowadays, all one has to do for a pair of nice flowing, cnc ported 906 heads is make a call to Dave at KG engines in Kansas Ohio.
He’ll fix you right up for a very reasonable price.
My days of high effort ported factory iron are over!!
Jerry Killian ported this last slant 6 head I have. He said the ONLY reason he did it was because he had ported one for me before, plus he agreed a long time ago to do another one. He said after this one, he was not porting anymore iron heads again. Ever. LOLI’m right with you. I probably turn down 2-3 porting jobs monthly because of them being cast iron.
