power booster check valve
scamp1973
Active Member
monroe,ct
how do you check it to make sure its working properly..i don't want to replace the booster if I don't have to
Start the engine and let it idle. Apply the brakes once or twice so you know what you are "feeling."
Stop the engine for ?? 10 seconds, and apply the brakes ONCE and pay attention to "how they feel." They should feel just like the engine is running
Apply them again
And a third time. Sometime in the second and third stroke, the pedal should change feel, become firmer, and "no boost."
What you are "feeling" is the depletion of the reserve vacuum stored in the booster
Try to blow through it both directions. If its good air will pass only one way.
