[WANTED] Pre 67 A904 torque converter
Sheldon Belden
Meridian Idaho
Rating - 0%
0   0   0
I am in need of a torque converter for my 66 dart it's a stock /6 with the a904 transmission. I did some research and it's a 18 spline tc from a 1967 and older a904 transmission. I have looked at summit and could not find an 18 spline like I need. I finally had a chance to put the transmission back together and installed to find the torque converter is bad. I also need the transmission cooler lines if anyone has a set of braided lines laying around
I had the same issue but for a high performance issue. Couldn't find one. Do what I did. Send the converter out to be rebuilt.
I've got a stock '65 slanty convertor. It worked fine when I pulled it a few years ago.
