Problem Starting Up
gerardo
Texas
74 Dodge Dart Swinger Slant 6 This is my problem starts up once w/key no problems, I'll have the engine on idle for up to an hour, turn it off, then it won't start up again. Put in new control box, ballast resistor, starter relay, coil, cap rotor, spark plugs, starter, battery, neutral safety switch. Please help on what you think I could do! Going crazy!!!!
Check Fuel pump, Had a 318 Dart do that to me once, Was in school at the time teacher couldnt find nothing till we attempted to drive it out and it quit and was the fuel pump. Would shut down once warmed up try or look at that D
checked out pick up coil,gap to open adjusted to .008 now car starts evry time. thanks everybodies support
Can you explain what gap you measured? I would like to check this out on my car
The star wheel/ reluctor gap in the dist. Use a .008 non-magnetc, usually brass feeler ga. some feeler ga. sets come with a .008 brass blade
