sport74
Fellas, I have a new 408, has 10.65:1 comp, using a new tuff stuff mini denso starter. I have a good battery, and my timing is set to 10* BTDC. Stock wiring from the battery to the starter. Every time I try to start the engine, it spins freely for 3 to 4 complete rotations then begins to slowly drag. If you can get it fired in that window, evryrhever is ok. If not you have to wait for the wires to cool. Remove the plugs and it'll spin fine. Put them back in and it starts dragging again. It would spin fine prior to the first start up, but as soon as we had it running (30 seconds) then it stalled, that is when this problem started. At this point, I'm thinking the newer starter is pulling too many amps and the higher compression isn't helping the situation. Any advice is greatly appreciated.
